Add adresses with loop script
Hi all,
I have this script:
:for e from 101 to 150 do={
/ip address add address=(“10.150.” .$e .“.1/24”)
interface=($e)
When i run it thru terminal i get the error invalid value for argument address
Does anyone have a clue what i am doing wrong?
Thank you very much,
Your script works.
Do you have the correct name of your interfaces?.
I mean interface name 101,102,103…150 ?
Yes these are vlan interfaces and are called 101, 102, 103 etcetera. When i enter the address by hand in the CLI it works:
[admin@MikroTik] > /ip address add address=10.150.101.1/24 interface=101
[admin@MikroTik] >
Hi.
I have test your script whit 3 interfaces and works
:for e from 101 to 103 do={
/ip address add address=("10.150." .$e .".1/24") \
interface=($e)
I tested vlan and bridge interface.
What RouterOs version do you have?, is it the latest?
This is strange. Yes i have upgraded to the latest version 6.39.2. Absolutely no clue why this is going wrong. I will reset and try again.
Thnx
