add AP to routerOS
hellooooo:D
i have get R OS 433Ah and xr2 card and run it as ap mode
i want to add anew access point TP-link501 on system
the problem is when i add access from registration menu and copy it to access list i try to connect from my labtop via tp-link but give me hotspot message mean that “mac is used”
this message is appear when another pci wireless card connect direct to mikrotik or through access i want to know which mode i shuld select in tp-link??(point to point,clinet,repeater,…) and what i must adjust in xr2 configuration ?
iwant tp-link run wired and wirless
note: i use 3.14 virsion and use hotspot and made acc.per mac=0 on it and try to add user(cards) in hotspot user with mac and without mac(try both)
DHCP server is enable and access only give ip to clinet only in universal repeater mode!!!
plz help me
any one helllllllllllp meeeeeeeeeee
Ahmed .. try to set TPLink as Access Point, make channel and SSID same with channel and SSID RouterOS. Enable WDS at RouterOS, you can make ignore ssid too.
-muhti.
