Add Christmas lights to Chateau 12 router
Since this router does not have beeper and you can’t play songs on it, but it does have controllable LEDs, so you can give it some Christmas vibes.
Video: https://i.imgur.com/8380H4K.mp4 (imgur post).
WARNING - High amount of sector writes. It will eventually kill your flash storage with the time.
Do some initial configuration:
# Disable modem-signal functionality for leds
/system leds set [find where type=modem-signal] disabled=yes
# Add dummy rule so led1 is enabled
/system leds add type=on leds=led1
Then add below scheduler:
/system scheduler add interval=1s name=schedule1 on-event="/system leds set [find where type=on] leds=led2,led4\r\
    \n:delay 0.25\r\
    \n/system leds set [find where type=on] leds=led1,led3,led5\r\
    \n:delay 0.25\r\
    \n/system leds set [find where type=on] leds=led2,led4\r\
    \n:delay 0.25\r\
    \n:delay 0.25" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=dec/22/2020 start-time=22:07:44
Post a movie
Done. I’ve updated initial comment.
