Add default route on L2TP client doesn't take into acocunt VRF
Ros 7.1 on an RB4100, if you tick the box to add default route on the l2tp client (Presumably other PPP Clients as well, haven’t tested) it will add the default route to the main table even if the PPP interface is in a VRF.
This should really add the route to the VRF the interface is present in.
