I need our clients to be able to just type in “username” instead of “username@domain”. I tried to do this by using the following in the login.html file:
By looking at the log, it successfully added the domain, but I get the error of “Wrong username or password” no matter whether I use “username” as the username or “username@domain”.
Is there anyway to modify the following in the login.html to add “@domain” to the username? <input type=“text” class=“textbox” %input-user% size=“18”>
We have a few other locations that we use an external hotspot page along with radius. None of these users (250+) have to type in “@domain” at the other sites since the external hotspot page adds it to their username.
At this location, we already have a number of local users (not via radius) that do not use a domain name. We want to continue to use the local hotspot page so the existing users will be authenticated via the local database, but for users not in the local database, they will be authenticated via radius.
Basically, we would have to re-train approx 300 users to start using “@domain”. Please note that we only have one domain so that is why I would like to automate it.
I havent tried this with MT, but usually the handling of @domain is a feature of the radius server. Done this a lot with dialup and the modem servers are dumb to the process. Domains are called realms in radius.
Not sure the capabilities of other radiuses but we use Radiator, in which
you can assign a client identifier to the client Id, for example Big Mountain-AP, then Authenticate By a rule which includes the client AP id with the user name ie username, Big Mountain-AP. In that authby you can add
a custom domain specific to that accesspoint, after previously stripping off
any domain that might be there.
