Add mib file failed
I want to upload mib file to the directory mib.
This in “files” Ultra (USB stick) but it failes.
I can see the MIB file in the root of the Ultra USB stick
But can not drag to the directory Mib.
How do I add it?
I can’t move the file to the mib directory.
This is a externe usb-stick.
Nowbody knows?
Mikrotik?
I suggest you try to move it through FTP (Filezilla or WinSCP) :smiley:
Otherwise, we’ll have to learn how to change permissions in those folders via terminal. :confused:
I try that but don’t work.
Use only “(data-path)/files/” directory. All other directories have read only permissions
http://wiki.mikrotik.com/wiki/Manual:The_Dude_v6/Files
So if I put it in “(data-path)/files/” how do I get the server to acknowledge that they are there and start identifying those devices?
