seems current PCQ classifiers (dst-ip-addr, src-ip-addr) working only on etherType=0x800=ip packet
when device working in bridge mode and bridging packets, when it’s attached QUEUE on INTERFACE, it’s only classyfing plain IP packets.
Packets with etherType=pppoe sesssions, or packets with VLAN header, or Vlan-in-Vlan header ARE NOT BEING PLACED IN PCQ QUEUE!
I think best solution will be to add two PCQ classifiers: src-mad-addr, dst-mac-addr - then we don’t care what services being bridged through…
If you are also doing queues on the pppoe server, and your transport / backhaul network is using vlan tags, then your marking rules on the pppoe server could also set a dot1p priority (cos) flag on the vlan headers. Middle switches could queue based on dot1p.
Other than that, you’re out of luck for prioritizing traffic within a tunnel.
hmmm - I would have thought that wmm might support this. It’s always one of those shadowy things that’s always just below the surface, doing its job, and you cannot configure it. (QoS is this way in Ubiquiti also)
First of all it is important to know if you use use-ip-firewall in bridge settings.
Second, it is not good practice to limit traffic after encapsulation happened, you need to limit traffic before you encapsulate traffic into pppoe packet.
So i would suggest to move your queues to HTB Global, or to the simple queues, Where you can work with IPs.
