Add new Prob to hundreds servers
I didn’t find any proper way to solved it, I am sure that there is a simple way
I have created a new probe and I need to add it to all my devices, is there a way I can add the new prob it without entering to each device?
I really appreciate any help you can provide
you can try adding your servers’ networks to the discovery list. It will force a service discovery for all devices on the specified network and will add the new probe.
keep in mind that it will also re-add all the probes you removed from a specific device.
If you already have a probe added to the devices…
You can go to probes, copy the already added probe then paste it. The pasted probe will be associated with the same devices as the original. You can then change the settings on the pasted probe.
