Hello! I’m trying to add this script by telnet (I only have activate telnet in the router). I toke the script from this site http://wiki.mikrotik.com/wiki/Dynamic_DNS_Update_Script_for_DNSoMatic.com_behind_NAT. When I add the script it appears like Invalid, so it doesn’t work and I don’t know why. Ideas? Thanks for your time!
/system script
add name=OpenDNS policy=write,read,test,policy source=“#\r
\n# DNSoMatic automatic DNS updates\r
\n#--------------- Change Values in this section to match your setup ------------------\r
\n# User account info of DNSoMatic\r
\n:local maticuser "honorato.daniel@gmail.com"\r
\n:local maticpass "***************"\r
\n# Set the hostname or label of network to be updated. This is the part after the double colon (:
on the DNSoMatic services page.\r
\n# Hostnames with spaces are unsupported. Replace the value in the quotations below with your host names.\r
\n# To specify multiple hosts, separate them with commas. \r
\n# Use "all.dnsomatic.com" for the matichost to update all items in dnsomatic with this IP.\r
\n:local matichost "all.dnsomatic"\r
\n#------------------------------------------------------------------------------------\r
\n# No more changes need\r
\n:global previousIP;\r
\n:log info "Fetching current IP"\r
\n# Get the current public IP using DNS-O-Matic service.\r
\n/tool fetch url="http://myip.dnsomatic.com/\” mode=http dst-path=mypublicip.txt\r
\n# Read the current public IP into the currentIP variable.\r
\n:local currentIP [/file get mypublicip.txt contents]\r
\n:log info "Fetched current IP as $currentIP"\r
\n \r
\n:if ($currentIP != $previousIP) do={\r
\n :log info "DNSoMatic: Update needed"\r
\n :set previousIP $currentIP \r
\n# The update URL. Note the "\3F" is hex for question mark. Required since is a special character in commands.\r
\n :local url "http://updates.dnsomatic.com/nic/update\3Fmyip=$currentIP&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG"\r
\n :local matichostarray;\r
\n :set matichostarray [:toarray $matichost];\r
\n :foreach host in=$matichostarray do={\r
\n :log info "DNSoMatic: Sending update for $host"\r
\n /tool fetch url=($url . "&hostname=$host") user=$maticuser password=$maticpass mode=http dst-path=("dnsomaticupdate-" . $host . ".txt")\r
\n :log info "DNSoMatic: Host $host updated on DNSoMatic with IP $currentIP"\r
\n }\r
\n} else={\r
\n :log info "DNSoMatic: Previous IP $previousIP and current IP equal, no update need"\r
\n}
