Add SSTP Server Binding to bridge
I have several subnets configured in my mikrotik router - the subnets are not allowed to see each other.
When a client connect via SSTP to the mikrotik I want this user to be part of the subnet, he belongs to. So I configured for each subnet a separate ppp profile and assigned it to the user (via ppp secret). Using this way, user1 for subnet1 gets a DHCP-IP from subnet1 and user2 a DHCP-IP from subnet2.
The problem is, that both user are not able to see anything in the private subnets - all of the packets are dropped. So I thought assigning “bridge” to the ppp-profile will add the sstp interface to the local subnet bridge - but that changed nothing.
I found two ways:
  • Adding a firwall rule “forward 10.129.0.0/16 → 10.129.0.0/16 allow” (which sounds weird for me)
  • Adding a SSTP-Server Binding for the user and adding a firewall rule “Server Binding → Bridge allow” (which is more or less the same)
My question:
  • Is there a possibility to add a SSTP-interface to a Bridge to give the SSTP-User full control in the subnet?
  • if not: which is the “correct” way of doing that?
Thanks for any help!
Holger
Sstp is not L2 tunnel so it is not possible to bridge it. Use routing over it. If you need bridge, try eoip.
