Add to netwatch: arp-ping/interface and route table?
very convenient it would be if the functional netwatch would be expanded.
  1. route table for classic l3-ping.
is a simple way to select the switch uplink of providers (example: ping 1st priot provider with them route table or other action stuff, when work another table as main for reserve provider). there is no need to make a separate script for the command ping.
Host:
Interval:
Timeout:
Routing Table:
(may be other stuff from tools->ping like TTL, Src Address… don’t fragment/fragment may be?)
and
  1. arp-ping (of course, + interface)
is a simple way to check connection for icmp-block users/servers.
can u think about it?
I know. this can be solved by means of the classical script and schedule, but I also know that you love to do good things that simplify the lives of users :slight_smile:
