I’ve recently changed LTE provider. The previous setup had a WifiAP ( RBwAP2nD) run off LAN2 of the LTEkit, but the new provider put in their own LTE6 in a new location, and were not willing to re-connect the “old” WifiAP to it. I’ve now recovered the WifiAP from the old pole & want to add it back into the SXT6.
I lack the documentation from the earlier install to see if the WifiAP is best added to LAN 1 or 2 of the LTEkit/SXT6 nor if it need to use “bridge” or “pass-through”.
Some guidance as to how best to achieve the reintroduction of the WifiAP would be appreciated, with the minimum change to the SXT6 configuration, as I have no wish to upset my LTE provider.
Hopefully the two Config files are attached
WifiAPNov2023.cfg.rsc (1.43 KB)
LTE-Nov2023.rsc (4.3 KB)
