Hay,
I installed today wirless pci netgear g311 v3 to my server runing MT 2.9
How i can let the server found the card becuase now server dont see the wilress network card?
please only use wireless cards with Atheros chipset
Airlink101 makes a 108Mbit card that works well and is VERY cheap !!
i get anothr card
Tp-link tl-wn650g (atheros chipest)
and MT found the crad
the problem when i setup everything every few minutes the server hang and i have to restart again
any soultion?
change the server
the server runing fine 100% without wirless pci card
The problem start when i activate and enable the wirless from winbox its start happen
Try to not use shit products . I have a pcmcia tp-link card . After a while my windows computer freeze . If i unplug the card on this state, everything is ok .
Tp-link wireless is a shit .
Who made the chipset on the motherboard?
Well, zerounu, it seems your are from RO.
I have tens of tp-link cards, and they are working all but perfect. I have lost a single card from about 50 ( and that due to improper grouding) , vs. 4 r52h of 4, and a few others, with much higher death rate.
The initial problem of the thread initiator is almost sure the mb of the router the card is put into.
