Adding a Service to Multiple Devices
Is there a way to select multiple devices and add a service to poll for on the selected devices?
I don’t think you can with out using some trickery (I would not try it). The other solution is to setup auto discover so that probes you want added get added automatically.
The trickery method I speak of is “copy a probe” paste that probe into notepad, you will see that every device that the probe is installed on is in the XML. You could edit that XML and paste that probe back into the probes panel. SCARY!!! Don’t blame me… BACKUP YOUR DUDE FOLDER AND CONFIG!!!
