Adding Additional Network Maps
I had the Dude installed on one of my machines and began manually setting up a variety of maps {infrastructure, clients} only once I had created the 3rd Map the Dude only displayed Loading… when I I tried to access the last maps created, but I could open the primary map.
So I thought it might help to un-install The Dude and re-download it to re-install it once again.
The default map functions fine, but as soon as I add a new Map and try to access the new map I only see the Loading… warn.
What is causing this event to occur?
Has anyone experienced this and found the fix?
are you creating the maps as sub map or on the side panel?
Thank you for the reply…
I have been adding the maps so far from the left side panel I am pretty sure
Should I actually be utilizing SubMap option?
This would be great as I am trying to create maps for each class of wireless client on my system for monitoring to save confusion amongst 5 classes of users basically.
Thank you very much once again for the response :slight_smile:
Kindeest Regards
Pat Taylor
