I thought I had it figured out but none of my AP’s are broadcasting a new SSID I created on Capsman router. Any Ideas on what I may be missing? New SSID is FAFC-Guests
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled frequency=2412,2437,2462 name=2G4
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=Ce frequency=5180,5200,5220,5240,5260,5280,5300,5320 name=5G
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=SFSCS passphrase=****
add authentication-types=wpa2-psk encryption=aes-ccm name=FAFC passphrase="****"
add authentication-types=wpa2-psk encryption=aes-ccm name="FAFC Guests" passphrase="****"
/caps-man configuration
add channel=2G4 country="united states" datapath=SFSCS distance=indoors installation=indoor mode=ap name=SFSCS-2G security=SFSCS ssid=SFSCS
add channel=5G country="united states" datapath=SFSCS distance=indoors installation=indoor mode=ap name=SFSCS-5G security=SFSCS ssid=SFSCS
add country="united states" datapath=FAFC distance=indoors installation=indoor mode=ap name=FAFC-2G security=FAFC ssid=FAFC
add country="united states" datapath=FAFC distance=indoors installation=indoor mode=ap name=FAFC-5G security=FAFC ssid=FAFC
add country="united states" datapath=FAFC distance=indoors installation=indoor mode=ap name=FAFC-Guests-2G security="FAFC Guests" ssid="FAFC Guests"
add country="united states" datapath=FAFC distance=indoors installation=indoor mode=ap name=FAFC-Guests-5G security="FAFC Guests" ssid="FAFC Guests"
/caps-man datapath
add bridge=bridge local-forwarding=yes name=SFSCS vlan-id=10 vlan-mode=use-tag
add bridge=bridge local-forwarding=yes name=FAFC vlan-id=20 vlan-mode=use-tag
/caps-man interface
add configuration=SFSCS-2G disabled=no l2mtu=1600 mac-address=E4:8D:8C:72:DB:2A master-interface=none name=cap1 radio-mac=E4:8D:8C:72:DB:2A radio-name=\
E48D8C72DB2A
add configuration=FAFC-2G disabled=no l2mtu=1600 mac-address=E6:8D:8C:72:DB:2A master-interface=cap1 name=cap2 radio-mac=00:00:00:00:00:00 radio-name=\
E68D8C72DB2A
add configuration=SFSCS-5G disabled=no l2mtu=1600 mac-address=E4:8D:8C:72:DB:29 master-interface=none name=cap3 radio-mac=E4:8D:8C:72:DB:29 radio-name=\
E48D8C72DB29
add configuration=FAFC-5G disabled=no l2mtu=1600 mac-address=E6:8D:8C:72:DB:29 master-interface=cap3 name=cap4 radio-mac=00:00:00:00:00:00 radio-name=\
E68D8C72DB29
<snip - a boatload of cap# interfaces are here - snip>
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-enabled hw-supported-modes=b,g,gn master-configuration=SFSCS-2G slave-configurations=FAFC-2G,FAFC-Guests-2G
add action=create-enabled hw-supported-modes=a,an,ac master-configuration=SFSCS-5G slave-configurations=FAFC-5G,FAFC-Guests-5G
