Adding Dragonwave MIB's into the DUDE?
Has anyone had any luck using Dragonwave Radio MIB’s for the Horizon Compact Microwave Radios with the Dude? I downloaded the latest Horizon Compact MIB’s from Dragonwave and put them in the files section in The Dude but the Mib Nodes lists missing iports (see attached picture).
Has anyone run into this issue or have any recomendation? I would like to be able to Monitor my Dragonwave signal strength in The Dude if possible using their MIB’s.
Thanks,
Jim
I too am interested in this.
I just last night got DUDE working, and added my DW’s
i may do some trial and error testing later but keep the thread updated if you have any luck, ill do the same.
I did some additional testing, and even with the errors, I am able to snmp walk the dragonwave devices using a couple of the Dragonwave MIB’s. The problem is though I would like to be able to see the signal strength (and notify based up it going too low) in DUDE, however even in snmp walk I don’t see the signal strength. I’ll advise if I make any progress on this.
