I am looking for some additional security to block attacks directly at the perimeter.
What I found, is:
Suricata-integration with ETPro-rules
Looks great, but it’s hard to decide and manage which rules should be blocked, because there is no “severity” level at the rules.
Axiom Cyber Shild
I found that professional add-in for mikrotik that claims to add dynamic firewall rules: https://axiomcyber.com/shield/
Is anybody here using that product? What are your thoughts about it?
Hmm..MT is absolutely not a “next-generation” player in the firewall area…filtering at L7 is getting more & more useless and kills the performance of these units.
My MikroTik has a firewall? Yes! Mikrotik’s firewall capabilities outperform some of the most expensive and elaborate firewall solutions from the “other guys”. It is considered next-generation which means it can do Deep Packet Inspection (DPI) and also track connections like a stateful firewall but also able to filter up to Layer 7. At Axiom, we utilize these tools to protect networks at the ingress to stop repeat offenders from probing or attempting to penetrate your network. We also catch a lot of stuff going out the egress such as ransomware, tor (DarkWeb), torrenting, and more.
Doing some testing at the moment, so the first view is winmtr to that IP from a non loaded router.
If able will load up a second router with the rules in place…
