How can I add filter or nat rules without adding the rule in the last position then using ‘move’ to change the sequence?
Should be able to squeeze a new rule in-between other rules without using 2 commands instead of just one.
I want to use a script to regenerate 2 NAT rules once a tunnel goes up, these seem to always appear on the last 2 positions.
Strangely, nothing in the wiki…Should be just like Cisco ACL’s, easy, but it’s not.
