Adding one of multiple CAPSMAN virtual ssids to local bridge
I am running a capsman that is provisioning multiple virtual ssids to multiple CAPS
On one of the CAPS I want to be able to add an additional virtual SSID (this I have managed), with local forwarding.
The virtual interface is created, but i would like to know how to add it to a local bridge on the cap automatically
Please help
When using local forwarding, on the CAP side, you go to wireless cap tab and at the bridge field you select the Bridge you want the interface to be dynamically added.
So at the time the CAP gets succesfully provisioned the wireless interface will be added to the Bridge…
In capsman forwarding the method is different…
