I’m trying to add into scheduler → ‘on-event’ two lines using php class (http://wiki.mikrotik.com/wiki/API_PHP_class) by code:
$api->comm(‘/system/scheduler/add’, array(
“name” => ‘upgrade_system’,
“interval” => ‘5s’,
“on-event” => “/system scheduler remove upgrade_system.
/system identity set name=‘system upgraded’” ));
but the second line of “on-event” is not transfered to MT. The debug mode shows below information:
Connection attempt #1 to 185.118.213.50:8728…
<<< [6] /login
[5/5] bytes read.
[5, 39]!done
[37/37] bytes read.
[37, 1]=ret=2d2412e5c9f35879f264274b091be9d2
<<< [6] /login
<<< [11] =name=admin
<<< [44] =response=007513c6ac0e7e68356cc16ce3f652aa09
[5/5] bytes read.
[5, 1]!done
Connected…
<<< [21] /system/scheduler/add
<<< [20] =name=upgrade_system
<<< [12] =interval=5s
<<< [49] =on-event=/system scheduler remove upgrade_system
<<< [32] /system identity set name=‘test’
[5/5] bytes read.
[5, 10]!done
[8/8] bytes read.
[8, 1]=ret=*82
Disconnected…
Please help in solving this problem.
br
Piotr Polok
