Adding Single and Bulk Vouchers to UserMan
i’m currently building small web app to manage Mikrotik router and i stucked in adding Bulk of users/vouchers to UserMan using Python code , i succefully add single user/voucher but in bulk the users/vouchers added without assigning profile. the code is attached
# (نفس الكود بدون تغيير حتى نصل إلى الأماكن المعدّلة)
@app.post("/api/add-user")
async def api_add_user(request: Request):
    login = request.session.get("login")
    if not login:
        return JSONResponse({"message": "غير مصرح"}, status_code=401)
    data = await request.json()
    api, api_pool = connect_to_router(login["ip"], login["username"], login["password"], login["port"])
    try:
        cmd = f'/tool user-manager user add username="{data["username"]}" password="{data["password"]}" customer=admin shared-users=1'
        out, err = run_ssh_command(login["ip"], login["username"], login["password"], 22, cmd)
        if 'not found' in err.lower():
            cmd = f'/user-manager user add username="{data["username"]}" password="{data["password"]}" customer=admin shared-users=1'
        if err:
            return JSONResponse({"message": f"خطأ في إضافة المستخدم: {err.strip()}"}, status_code=500)
        if data.get("profile"):
            time.sleep(1)
            cmd_activate = f'/tool user-manager user create-and-activate-profile numbers={data["username"]} customer=admin profile={data["profile"]}'
            out_activate, err_activate = run_ssh_command(login["ip"], login["username"], login["password"], 22, cmd_activate)
            if err_activate:
                return JSONResponse({"message": f"تم إضافة المستخدم لكن حدث خطأ في تفعيل البروفايل: {err_activate.strip()}"}, status_code=500)
        return JSONResponse({"message": f"تمت إضافة المستخدم {data['username']} بنجاح"})
    except Exception as e:
        return JSONResponse({"message": str(e)}, status_code=500)
    finally:
        api_pool.disconnect()
@app.post("/api/add-vouchers-batch")
async def add_vouchers_batch(request: Request):
    if not login:
    try:
        vouchers = []
        for _ in range(data["count"]):
            max_attempts = 10
            for attempt in range(max_attempts):
                username = generate_username(data["prefix"], data["username_length"], data["username_type"])
                password = generate_password(data["password_length"], data["password_type"])
                try:
                    commands = [
                        f'/tool user-manager user add username="{username}" password="{password}" customer=admin shared-users=1'
                        commands.append(f'/tool user-manager user create-and-activate-profile numbers={username} customer=admin profile={data["profile"]}')
                    results = run_ssh_commands(login["ip"], login["username"], login["password"], 22, commands)
                    add_out, add_err = results[0][1], results[0][2]
                    if add_err:
                        if "already exists" in add_err.lower():
                            if attempt == max_attempts - 1:
                                vouchers.append({
                                    "username": username,
                                    "password": password,
                                    "profile": data.get("profile", ""),
                                    "status": "error",
                                    "error": "تعذر توليد اسم مستخدم فريد بعد عدة محاولات"
                            continue
                        else:
                            vouchers.append({
                                "status": "error",
                                "error": f"خطأ في إنشاء المستخدم: {add_err.strip()}"
                            break
                    if not data.get("profile"):
                        vouchers.append({
                            "profile": "",
                            "status": "success"
                        break
                    if len(results) > 1:
                        activate_out, activate_err = results[1][1], results[1][2]
                        if not activate_err and "error" not in activate_out.lower() and "no such item" not in activate_out.lower():
                            vouchers.append({
                                "profile": data["profile"],
                                "status": "success"
                        else:
                            vouchers.append({
                                "status": "warning",
                                "error": f"تفعيل البروفايل فشل: {activate_err.strip()} {activate_out.strip()}"
                    break
                    vouchers.append({
                        "status": "error",
                        "error": f"خطأ غير متوقع: {str(e)}"
                    break
        successful = len([v for v in vouchers if v.get("status") == "success"])
        warnings = len([v for v in vouchers if v.get("status") == "warning"])
        errors = len([v for v in vouchers if v.get("status") == "error"])
        message = f"تمت إضافة {successful} من {data['count']} Voucher بنجاح"
        if warnings > 0:
            message += f" ({warnings} تم إنشاؤهم مع تحذيرات)"
        if errors > 0:
            message += f" ({errors} فشل إنشاؤهم)"
            "message": message,
            "vouchers": vouchers,
            "stats": {
                "total": data["count"],
                "successful": successful,
                "warnings": warnings,
                "errors": errors
            "message": f"حدث خطأ: {str(e)}",
        }, status_code=500)
    finally:
@app.get('/api/test-um-ssh')
def test_um_ssh(request: Request):
    login = request.session.get('login')
    if not login:
        return JSONResponse({'message': 'غير مصرح'}, status_code=401)
    cmd1 = 'tool user-manager user add username=nnnb password=1234 customer=admin shared-users=1'
    out1, err1 = run_ssh_command(login['ip'], login['username'], login['password'], 22, cmd1)
    cmd2 = 'tool user-manager user create-and-activate-profile numbers=nnnb customer=admin profile=500YR-1.5G'
    out2, err2 = run_ssh_command(login['ip'], login['username'], login['password'], 22, cmd2)
        'add_out': out1, 'add_err': err1,
        'activate_out': out2, 'activate_err': err2
# ... باقي الكود كما هو
