I have two routers connected via IPSEC/IKEv2 in tunnel mode. They don’t have explicit firewall NAT bypass rules added. They have this instead:
add name=vpn-blackhole
add comment="Blackhole for RFC 1918" distance=5 dst-address=10.0.0.0/8 gateway=vpn-blackhole
add comment="Blackhole for RCF 1918 class B" distance=5 dst-address=172.16.0.0/12 gateway=\
vpn-blackhole
add comment="Blackhole for RCF 1918 class C" distance=5 dst-address=192.168.0.0/16 gateway=\
vpn-blackhole
And it works! I have another two devices where the same thing does not work, and I cannot figure out why. I was so frustrated that I went into big depths with this problem. I have installed GNS3, created virtual CHR routers and virtual machines. All of this just to find what the problem is, but I still don’t know.
Here is my test network:
The internet is simulated with the top router. The two sites are connected to it with two more routers. All of the routers are running RouterOs CHR in VMWare.
Since this environment was created just to find the solution to this problem, I’m going to post full unaltered configs here.
Here is the config for the “office” site:
add name=bridge-office
set [ find default-name=ether1 ] name=ether1-internet
add name=LAN
add name=WAN
/ip ipsec policy group
add name=branch01.myserver.hu
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=myserver.hu proposal-check=strict
/ip ipsec peer
add exchange-mode=ike2 local-address=100.3.3.10 name=peer-branch01 passive=yes profile=myserver.hu
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=proposal-myserver.hu pfs-group=modp2048
add name=pool-office ranges=172.16.2.100-172.16.2.200
add address-pool=pool-office disabled=no interface=bridge-office name=dhcp-office
add bridge=bridge-office interface=ether2
add bridge=bridge-office interface=ether3
add interface=ether1-internet list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add address=172.16.2.1/24 interface=bridge-office network=172.16.2.0
add address=100.3.3.10/24 interface=ether1-internet network=100.3.3.0
add address=172.16.2.0/24 dns-server=172.16.2.1 gateway=172.16.2.1
set allow-remote-requests=yes servers=100.3.3.3
add action=accept chain=input comment="Allow UPD 500,4500 for IKEv2" dst-address=100.3.3.10 dst-port=500,4500 in-interface=ether1-internet protocol=udp
add action=accept chain=input comment="Allow IPSEC/ESP" dst-address=100.3.3.10 in-interface=ether1-internet protocol=ipsec-esp
add action=accept chain=forward ipsec-policy=in,ipsec
add action=accept chain=forward in-interface-list=LAN src-address=172.16.2.0/24
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=change-mss chain=forward comment="IKE2: Clamp TCP MSS from 172.16.1.0/24 to ANY" ipsec-policy=in,ipsec new-mss=1360 passthrough=yes protocol=tcp src-address=172.16.1.0/24 \
tcp-flags=syn tcp-mss=!0-1360
add action=accept chain=srcnat comment="bypass nat for VPN tunnel between internal addresses" disabled=yes dst-address=172.16.0.0/12 src-address=172.16.0.0/12
add action=masquerade chain=srcnat out-interface=ether1-internet
/ip ipsec identity
add auth-method=digital-signature certificate=office.myserver.hu match-by=certificate my-id=fqdn:office.myserver.hu peer=peer-branch01 policy-template-group=branch01.myserver.hu \
remote-certificate=branch01.myserver.hu remote-id=fqdn:branch01.myserver.hu
/ip ipsec policy
add dst-address=172.16.1.0/24 peer=peer-branch01 proposal=proposal-myserver.hu sa-dst-address=100.2.2.10 sa-src-address=100.3.3.10 src-address=172.16.2.0/24 tunnel=yes
add distance=1 gateway=100.3.3.3
add comment="Blackhole for RCF 1918 class B" distance=1 dst-address=172.16.0.0/12 gateway=vpn-blackhole
/system identity
set name=office.myserver.hu
Here is the unaltered config for the “branch01” site:
add name=bridge-branch01
add name=LAN
add name=WAN
add name=office.myserver.hu
/ip ipsec profile
/ip ipsec peer
add address=100.3.3.10/32 exchange-mode=ike2 local-address=100.2.2.10 name=peer-office profile=myserver.hu
/ip ipsec proposal
add name=pool-branch ranges=172.16.1.100-172.16.1.200
add address-pool=pool-branch disabled=no interface=bridge-branch01 name=dhcp-branch01
add bridge=bridge-branch01 interface=ether2
add bridge=bridge-branch01 interface=ether3
add address=172.16.1.1/24 interface=bridge-branch01 network=172.16.1.0
add address=100.2.2.10/24 interface=ether1-internet network=100.2.2.0
add address=172.16.1.0/24 dns-server=172.16.1.1 gateway=172.16.1.1
set allow-remote-requests=yes servers=100.2.2.2
add action=accept chain=input comment="Allow UPD 500,4500 for IKEv2" dst-address=100.2.2.10 dst-port=500,4500 in-interface=ether1-internet protocol=udp
add action=accept chain=input comment="Allow IPSEC/ESP" dst-address=100.2.2.10 in-interface=ether1-internet protocol=ipsec-esp
add action=accept chain=forward in-interface-list=LAN src-address=172.16.1.0/24
/ip firewall mangle
add action=change-mss chain=forward comment="IKE2: Clamp TCP MSS from 172.16.2.0/24 to ANY" ipsec-policy=in,ipsec new-mss=1360 passthrough=yes protocol=tcp src-address=172.16.2.0/24 tcp-flags=syn tcp-mss=\
!0-1360
add action=accept chain=srcnat disabled=yes dst-address=172.16.0.0/12 src-address=172.16.0.0/12
/ip ipsec identity
add auth-method=digital-signature certificate=branch01.myserver.hu my-id=fqdn:branch01.myserver.hu peer=peer-office policy-template-group=office.myserver.hu remote-id=fqdn:office.myserver.hu
/ip ipsec policy
add dst-address=172.16.2.0/24 peer=peer-office proposal=proposal-myserver.hu sa-dst-address=100.3.3.10 sa-src-address=100.2.2.10 src-address=172.16.1.0/24 tunnel=yes
add distance=1 gateway=100.2.2.2
/system identity
set name=branch01.myserver.hu
I’m testing this from PC1=172.16.1.10 and PC2=172.16.2.10 - they are pinging each other with TCP ping continuously.
This is what I see on PC2:
Connect 7@172.16.1.10 timeout
*100.3.3.10 tcp_seq=7142 ttl=64 time=162.140 ms (ICMP type:3, code:1, Destination host unreachable)
Most of the time I just get timeout messages, but sometimes I get a “Destination host unreachable” from the 100.3.3.10 test router.
The same thing happens on PC1:
Connect 7@172.16.2.10 timeout
*100.2.2.10 tcp_seq=6193 ttl=64 time=156.605 ms (ICMP type:3, code:1, Destination host unreachable)
*100.2.2.10 tcp_seq=6207 ttl=64 time=161.157 ms (ICMP type:3, code:1, Destination host unreachable)
It proves that these packages are not going through the IPSEC tunnel. They are masqueraded and sent out on ether1-internet to the default gateway.
If I enable this first NAT bypass rule under /ip firewall nat
[admin@office.myserver.hu] /ip firewall nat> print
0 X ;;; bypass nat for VPN tunnel between internal addresses
chain=srcnat action=accept src-address=172.16.0.0/12 dst-address=172.16.0.0/12
1 chain=srcnat action=masquerade out-interface=ether1-internet
[admin@office.myserver.hu] /ip firewall nat> set 0 disabled=no
Then PC2 still cannot ping PC1 for about 10-30 seconds, then it starts to work. The same is true for the branch01 router - if I enable the manually added NAT bypass rule, then it works. Otherwise it doesn’t.
Here is what I don’t understand. These routers already have blackhole/fake routes to all B class networks:
I think this general masquerade NAT rule should not match:
add chain=srcnat action=masquerade out-interface=ether1-internet
But it does! In other words, I’m not able to bypass NAT by adding routes to portless bridges inside the test environment.
But if I do the same in production, then it works!
I spent two days putting together GNS3 and the whole test environment and I still don’t understand what is happening here. Pulling my hair out. ![]()
I apologize, it was a bit long introduction…
The basic question is this:
- On the office router, I have this static route to the portless vpn-blackhole bridge
- But the packets that should be forwarded from 172.16.2.0/24 to 172.16.1.0/24 are getting maqueraded, like if they are meant to be sent out on the ether1-internet interface. Why?
- Not that important but why does it work on other devices, and not on some others? (But I guess once I know the answer to the first one, I’ll also know the answer to the second one too…)
