I need to convert my queues to k vs bytes.
I’m sure it something stupid, how do I add that?
So i figured it out.. of course..
:global elseup (((($upspeed*$emu)/100)/1024).“k”);
This will use the upspeed times it by the EMU in this case 5, or 5%, divide that by 100 to get 5% of the upseed, then divide that by 1024 to covert to k, then use the .“k” to add the k at the end, then this variable can be set in the queues ![]()
why do you need the ‘k’? O_o
p.s. k = 1000, not 1024
Ki = 1024
