How do I add the following to an existing and working email script (it sends a telegram to my phone).
/ tool fetch "https://api.telegram.org/bot1111111111:t rAndomStrInGof lettersandnumbers/sendMessage?chat_id
=-222222222&text=Router $[/system identity get name] has detected the HP Printer Offline"
:log info "Telegram notification sent about HP Printer offline"
If the email script that works to send me an email is as follows when the DEVICE (printer) status is changed to DOWN:
:local sub1 ([/system clock get time])
/tool e-mail send from="myemail@address.com.ca" body="At $sub1 HP Printer is Offline" subject="HP Printer is offline" to="myemail@address.com"
:log info "CHECK HP printer stat!!"
Is there some special syntax to join to separate functions??
This does not work…
I finally got the Fetch script working the issue was a hidden return character or extra space that I had to remove.
Now my netwatch can fetch a script from systems scripts…
wow thats very advanced for me LOL, an automated master script that runs and updates a bunch of others…
I didnt understand your notification script so rather not use what I dont fathom.
What I would like is to know how to insert date/time or just time into my Fetch URL script.
This way isnt working very well with multiple scripts
It seems to work great in simple /tool email netwatch scripts…
/tool e-mail send from=“myemail@address.com” body=“At $sub1 HP Printer is Offline” subject=“HP Printer is offline” to=“myemail@address.com”
:log info “CHECK HP printer stat!!”
But I get poor results when using it in /tool fetch scripts in system scripts, when the time is within an URL. I often get no entry where the time should be.
