Adding UDP ON OPENVPN
I would like to ask Mikrotik to add UDP support on OpenVPN.
Regards,
Sent from my SM-N910C using Tapatalk
Please stop posting multiple times, we see your one topic already.
OpenVPN UDP support is implemented in v7, which is currently in private alpha testing.
Do you also plan to integrate OpenVPN with cert + key authentification only? (without username + password) as it is used in more and more services like airvpn.org
Normis,
Thanks for replaying. i believe it was an mobile application issue. Anyway. Thanks for answering my request.
