Adding users from external.
I would like to actuality hotspot users dialy from a table or text file but I don´t know how to make that send this table to Router or how modify users table in Routers.
Thanks.
Greetings!
Not necessarily the easiest but, in my opinion, the most flexible way is with a RADIUS server. I use FreeRADIUS, and it works well with MT hotspots.
Thank you for your help. Anybody knows other way?
Thanks.
the MT user manager can do this as well, same difference as any other auth system. The real story is what and how you wish to add users. What usernames/ etc. So that makes a difference .
Sorry, I don´t know how create users in webbox.
