Hi xvo, thanks for your patience. I do have a way of connecting the cap directly to the router via ethernet cable but tis a bit difficult and will keep it in mind as a last resort.
The two switches in the way are a managed switch DLINK DGS-1100-24 with no settings (default) and close to the cap AC a 16 port unmanaged zyxel switch.
I just reviewed the dlink settings and there is nothing on it that should prevent all traffic from flowing.
General settings
Ports - default
Jumbo State - disabled
Clock settings - correct
Port based VLAN - disabled
Managment VLAN: Vid 1, State: disabled
Assymetric VLAN State: disabled
Auto Video VLAN: disabled
Voice VLAN: disabled
Vlan settings 802.1q
VID: 1
Tagged Member Ports: blank (nil entries)
Untagged Member Ports: eth01-eth24
VLAN Type: blank (nil entry)
VLAN Interface Table
Ports: eth1-eth24, Vlan Type: Hybrid, Ingress checking: enabled, Acceptable Frame Type: Admit ALL
OKAY THIS POST I am using to TALK my way through the setup, so perhaps you can pick out where I have gone wrong from the following ;conversational approach:
Hex.
Bridge Name = “HomeBridge”
Port Eth2 is associated with the HomeBridge and is the port that goes to the Dlink Switch and to all locations.
HomeLAN (my wired LAN) is also on the HomeBridge
I created a VLAN (Vid=100) with name “GuestWifi_T&B_V100” with interface being the HomeBridge.
I created a dhcp pool for the VLAN
I created and address list for the VLAN (linked to the above vlan interface)
I created a DHCP Server for the VLAN ( (linked to the above vlan interface, and linked to the dhcp pool above)
I created a DHCP Network for the VLAN *****
**** There is no obvious link to the interface in the Network settings?? I did put in
- Network of 192.168.100.0/24
- Gateway IP of 192.168.100.1
- DNS Server IP of 192.168.100.1
Under IP Routes, the applicable VLAN Line entry show: DAC - the VLAN Interface with distance 0 and states is reachable.
For the INTERFACE MENU, when selecting the actual Bridge Entry in the Table area, and its VLAN Tab, the selection of VLAN filtering is NOT checked.
For the BRIDGE MENU, under the VLAN TAB, the HomeBridge is selected for bridge, and tagged elements include the HomeBridge and Ether2.
Lastly for FW rules. I have Forward DROP ALL ELSE rule in place as last rule and thus created a VLAN to WAN accept rule
source address 192.168.100.0/24
In-interface: VLAN-interface
Out-Interface-List: WAN
On the Cap AC
I ensured that the VLAN interface I created now has the same name.
The cap AC is running in default mode (like an AP I suppose).
Eth 1 is WAN and is connected physically to the unmanaged zyxel 16 port switch.
Eth 2 is not used.
The Cap AC has a bridge with default name: Bridge
I have two existing WIFI networks as there are two radios
There is a 2G network called DevicesAP and a 5AC network called Basement_WIFI
I created a Virtual AP called Basement_Guests off of the 5AC network.
For Bridge port interface purposes
eth1 connected to WAN is port 0 (designated port)
I put 2GHZ network on port 2 (designated port)
I put 5AC network on port 3 (designated port)
I put Virtual AP on port 4 (disabled port) ???
On the Interface list, under LAN i have both wifi networks, the Virtual AP and the VLAN BUT NO BRIDGE *****,
WAN is ether 1.
***** This is different from the Hex where the entries for m LAN are only HomeBridge (and eth4 which connects to my DMZ lan), and udner WAN my two ISPs.
The error could be here??
I am thinking that the proper entry here for Lan Interface on the capAC should be BRIDGE only ???
For the BRIDGE MENU, under the VLAN TAB, the “Bridge” is selected for bridge, and tagged elements include the Basement_Guests and Ether1. ###
Tagged ports is slightly different from the Hex, ether2 is the physical ethernet port for the hex and ether1 for the cap AC so that is consistent, however, on the hex we have identified the bridge but on the capAC we have identified the Virtual Access Point (and not the bridge)???
Address List: The only address list showing on the cap AC is the HomeLAN 192.168.0.1 list. Perhaps because the capAC is assigned a LANIP from the hex that this shows up. I do not remember assigning a list but if there was a default 192.168.88.X list I probably replaced with the Homelan list.
No DCHP networks or servers identified, no dhcp pools, no FW rules.
Under IP routes I see:
DAS 0.0.0.0/0 192.168.0.1 reachable
DAC 192.168.0.1 bridge reachable preferred source 192.168.0.xx (lanip of the bridge)
If nothing of the above warrants concern or change and you would like to see the config again let me know.
