Additional bridge interfaces can't access WAN
Hello, I’ve tried to configure a router so that it would have 3 different sub-nets:
  • 192.168.50.0/24 - (LAN_SERVERS_1,2) - Does not route to WAN
  • 192.168.100.0/24 (LAN_OFFICE_1,2) - Does not route to WAN
  • 192.168.88.0/24 - Routes to WAN (part of the defconf that came with the router)
WAN_TELIA: ISP No.1 (for security I replaced IP address in config to: 111.111.111.)
WAN_BALTNETA: ISP No.2 (for security I replaced IP address in config to: 222.222.222.
  1. I can confirm that DHCP and address pools for bridged interfaces (LAN_OFFICE_BRIDGE, LAN_OFFICE_SERVERS) are working correctly.
    This
  2. I have tried disabling all firewall rules to rule out the possibility of it being a firewall issue, still no WAN connection.
Could anyone tell me what I am missing and why only the defconf bridge interface does WAN routing while others two bridges fail to do so?
# mar/07/2019 10:50:34 by RouterOS 6.42.10
# software id = AY2G-6688
# model = 2011UiAS-2HnD
# serial number = 91E10A6BCC51
add name=LAN_OFFICE_BRIDGE
add name=LAN_SERVERS_BRIDGE
add admin-mac=74:4D:28:24:90:7B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether5 ] name=LAN_OFFICE_1
set [ find default-name=ether6 ] name=LAN_OFFICE_2
set [ find default-name=ether3 ] name=LAN_SERVERS_1
set [ find default-name=ether4 ] name=LAN_SERVERS_2
set [ find default-name=ether2 ] name=WAN_BALTNETA
set [ find default-name=ether1 ] name=WAN_TELIA
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country=lithuania disabled=no distance=indoors frequency=auto mode=\
    ap-bridge name=WLAN ssid=MC-MOB-AP wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="interface list for all wans" name=WANs
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=LAN_SERVERS_DHCP_POOL ranges=192.168.50.200-192.168.50.254
add name=LAN_OFFICE_DHCP_POOL_2 ranges=192.168.100.120-192.168.100.254
add comment="Pools where splitted due to old cisco config this may be removed \
    in the future" name=LAN_OFFICE_DHCP_POOL_1 next-pool=\
    LAN_OFFICE_DHCP_POOL_2 ranges=192.168.100.2-192.168.100.80
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=LAN_SERVERS_DHCP_POOL disabled=no interface=\
    LAN_SERVERS_BRIDGE name=LAN_SERVERS_DHCP
add address-pool=LAN_OFFICE_DHCP_POOL_1 disabled=no interface=\
    LAN_OFFICE_BRIDGE name=LAN_OFFICE_DHCP
add bridge=LAN_SERVERS_BRIDGE comment=defconf interface=LAN_SERVERS_1
add bridge=LAN_SERVERS_BRIDGE comment=defconf interface=LAN_SERVERS_2
add bridge=LAN_OFFICE_BRIDGE comment=defconf interface=LAN_OFFICE_2
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add bridge=LAN_OFFICE_BRIDGE comment=defconf interface=WLAN
add bridge=LAN_OFFICE_BRIDGE interface=LAN_OFFICE_1
add comment=defconf interface=WAN_TELIA list=WAN
add interface=WAN_TELIA list=WANs
add interface=WAN_BALTNETA list=WANs
add interface=LAN_SERVERS_BRIDGE list=LAN
add interface=LAN_OFFICE_BRIDGE list=LAN
add address=111.111.111.80/24 interface=WAN_TELIA network=111.111.111.0
add address=192.168.88.1/24 interface=ether9 network=192.168.88.0
add address=192.168.88.1/24 interface=ether10 network=192.168.88.0
add address=192.168.50.1/24 interface=LAN_SERVERS_1 network=192.168.50.0
add address=192.168.50.1/24 interface=LAN_SERVERS_2 network=192.168.50.0
add address=192.168.100.1/24 interface=LAN_OFFICE_BRIDGE network=\
    192.168.100.0
add address=222.222.222.130/30 interface=WAN_BALTNETA network=222.222.222.128
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=WAN_TELIA
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=222.222.222.130 name=router.lan
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
    d this subnet before enable it" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
    need this subnet before enable it" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
    Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment=\
    "MC, Class D, IANA # Check if you need this subnet before enable it" \
    list=Bogons
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=forward comment="defconf: accept established,related" \
add action=accept chain=input port=69 protocol=udp
add action=accept chain=forward port=69 protocol=udp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    Bogons
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=WANs
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface-list=WANs
/ip firewall mangle
add action=accept chain=prerouting dst-address=222.222.222.128/30 \
    in-interface=LAN_OFFICE_BRIDGE
add action=accept chain=prerouting dst-address=111.111.111.0/24 in-interface=\
    LAN_OFFICE_BRIDGE
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=WAN_TELIA new-connection-mark=WAN1_conn
    in-interface=WAN_BALTNETA new-connection-mark=WAN2_conn
    dst-address-type=!local in-interface=LAN_OFFICE_BRIDGE \
    new-connection-mark=WAN1_conn per-connection-classifier=\
    both-addresses:2/0
    new-connection-mark=WAN2_conn per-connection-classifier=\
    both-addresses:2/1
add action=mark-routing chain=output connection-mark=WAN1_conn \
    new-routing-mark=to_WAN1
add action=mark-routing chain=output connection-mark=WAN2_conn \
    new-routing-mark=to_WAN2
add action=masquerade chain=srcnat out-interface=WAN_TELIA
add action=masquerade chain=srcnat out-interface=WAN_BALTNETA
    ipsec-policy=out,none out-interface-list=WANs
add check-gateway=ping distance=1 gateway=111.111.111.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=222.222.222.129 routing-mark=\
    to_WAN2
add distance=1 gateway=111.111.111.1
add check-gateway=ping distance=2 gateway=222.222.222.129
/system clock
set time-zone-name=Europe/Vilnius
/system routerboard settings
set silent-boot=no
/tool mac-server
/tool mac-server mac-winbox
I find your LAN OFFICE and SERVER structure very confusing and I would get rid of it and figure out what is required by deciding what you are trying to accomplish in words.
Then a design can be found that fits your needs. What is the functionality that is driving you to have two pools but same subnet for example.
What is so unique about these four entities you have decided are needed?
replace the part above in red with
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
Where is dns???
add address=192.168.88.0/24 comment=defconf dns=192.168.88.1 gateway=192.168.88.1
Missing dhcp-server network for your lan server and lan office ???
anav thank you for your reply.
Those two sub-nets are meant to replace 2 physical routers in our network. Due to legacy issues we have to keep two separate sub-nets .50 and .100. Basically all SERVERS were running under .50 and all employee computers under .100
These two entries are a backups if accidentally remove a bridge named bridge. So that I will not lock myself out of router admin panel. I will clean this up later.
access to router (via winbox is handled in input rules (access to router) and ip services I think not by backup confusing and wrong bridgeport settings.
What I am saying is that I really dont care how many routers were used previously, one office pool should be good for all office workers, one server pool should be good for all servers etc…
If they need to be segregated for security reasons, create different vlans or subnets.
