Hi, i just got my first Routerboad and evaluating it. Seems really solid. I’m very new so I apologize if these are stupid questions.
Here is my scenario, (The router is currently set to the default settings)
I need to add ubiquiti radios to the router on 192.168.1.x with static IP’s but I want the DHCP clients (connecting through ubiquiti radios) to us a different subnet (192.168.88.x) I have tried adding a second address (192.168.1.1) and setting my computer to 192.168.1.2 but now i can’t ping 192.168.1.2 nor can I ping 192.168.88.1.
I have also noticed that if i set my computers static ip to 192.168.88.2 and gateway to 192.168.88.1 it pings everything ok but there is no DNS unless I use a DCHP assigned address.
I need to be able to lease more than 254 IP addresses. How can I set this up to allow a DCHP server to assign addresses from 192.168.88.2 to 192.168.90.254?
set primary=8.8.8.8 secondary=208.67.222.222 allow-remote-requests=yes
Now u have additional subnet on LAN side.
just add this address to ubiquiti radio device 192.168.88.XX/24
now make your pc’s dhcp lease static & use this address 192.168.88.XX/24
you will be able to access the router & ubiquiti radio from ur computer while users can’t.
use the default address & dhcp configration for clients.
If computer address is in the same subnet you should ping any host (if mask on every host is the same.
AD2)
Correct me if I am wrong - you set static IP with DNS server address (as your gateway) and there is no way to resolve domains ? What is your /ip dhcp network configuration and ip dns ?
AD3)
You can resize the dhcp pool in
/ip pool to 192.168.88.0/22,
/ip dhcp server network setting
remember to set the same mask in address setting and in dhcp network
