Additional WAN IP's for PPPoE clients
Hey guys, fresh-registered user, first ppost so take it easy on me :stuck_out_tongue:
I have a CCR1036-12G-4S set up at a site.
Ether1 connects to the ISP.
Then SFP1 & SFP2 are setup in a LAG to a HP Switch, which branches off to several different businesses.
Lets say Mikrotik WAN IP is 1.2.3.4
then I have an additional /27 block, lets say 126.58.65.32/27
and an addition /29 block, lets say 67.89.24.48/29
So far I have had all customers connect via PPPOE (server setup on mikrotik) and obtain a single /27 address.
i achieve this by setting up the first available host ip from the /27 which is 126.58.65.33 on ether1 on the mikrotik which is then used as a gateway for the rest of the /27 pool.
this all works well.
However now i have a customer who wants a /29 block and am unsure how to achieve this via pppoe.
do i still setup first host address from the /29 on ether1 then assign 2nd host to PPPOE connection? if this is correct, then how do i route the remaining IP block to this same customer, and how do they set it up on their end.
I have no clue what im doing at this point.
BUMP anyone?
I am now suspecting i may have to use a /27 address for this customer as his primary WAN IP, then route the /29 block to it. still unsure how to route it.
Why can’t you using static routing to /32 host in routing table when pppoe-client connects to your server?
So I’ve just changed the PPPOE customers main wan ip to one from the /27 range.
and made a static route from 67.89.24.48/29 to his wan ip which is /27. Does that look right?
