Address list not handled properly?
Hello, i have a big problem with a CCR1016-12G type of RB.
I am using Address list in the firewall rules but its not working.
I used already some lists and they are working correctly.
But now:
I want to allow traffic from 1.1.1.1 to 2.2.2.2 so i created two address list 1 for 1.1.1.1 and 2 for 2.2.2.2
I created a firewall forward rule, to allow 1 → 2 allow.
But its not working only with few address in list 2. Some of the IP in list 2 i can ping from list 1 but some of it i can’t.
If i create the same rule without address list
allow forward 1.1.1.1 → 2.2.2.2 then its working.
So no other FW rule blocking, no routing problem, because if i enter manually the IP-s, then its working.
What can be the problem?
Are you aware that most of the ip’s in address list 2 are not in 192.168.x.y range?
198.168.x.y <=> 192.168.x.y
Not sure if this is intentional or the actual cause of the problem.
