adlist and dns server
I am currently comparing the performance (block rate) of /ip/dns/adlist versus Pi-hole using the following setup:
  • Each client uses the router as its DNS server.
  • The Pi-hole server is set as the upstream DNS server.
  • Both the Adlist and the Pi-hole server have identical blocklists.
In theory, any domain queried against the router’s DNS server should be blocked locally and therefore not forwarded upstream to the Pi-hole.
However, in practice, I still see some requests appearing in Pi-hole’s query log with the status “blocked.”
Most of these requests are of type “HTTPS RR (RR type 65)” (more details: RFC 9460).
Corresponding log entries from the router show:
query from XXXXX: #78203 beacons3.gvt2.com. UNKNOWN (65)
This issue could potentially be resolved by adding support for “HTTPS RR (RR type 65).”
Feature Requests:
  • Support for “HTTPS RR (RR type 65)” to ensure proper blocking.
  • Logging for “blocked by Adlist” to track which client queried a blocked domain.
  • Support for addresses “0.0.0.0” and “::” with static entries (or a “block” option).
  • Static entry prioritization: If a static entry exists for a specific record type (e.g., “A”), other record types (e.g., “AAAA”) should not receive non-static responses. Currently, even when a static “A” record is present, an “AAAA” query still gets a non-static response.
I’ve asked for HTTPS RR support (at that time adlist didn’t exist yet, support was for caching and editing of static entries) on January 2024 and at that time this was MikroTik’s answer to the support ticket:
Thank you for contacting MikroTik Support.
Your feature request has been noted!
If there are similar requests, we will consider implementing such a feature.
Best regards,
So please fill a support ticket asking for it too so that they will “consider implementing” more :face_savoring_food:.
