Admin password - CRS125-24G-1S
Hello everyone,
I have switch CRS125-24G-1S, configured and didnt login maybe for 6 month.
Have saved user and password login in winbox, but now I cant login. It say wrong username or password.
Is there any way to reset password from console? I cant reset because backup not created.
Thnx
always.take.backups.
Reboot might help if the management interface just gone wonky.
You might be able to pull a config through the boot menu but I don’t think you can.
You’ll likely have to reset and reconfigure.
And use a password manager or similar solution for such cases. ( a Post-It on the device or next to your computer is NOT a good alternative …)
Don’t ever assume you will remember.
Thnx.
If only way to reset factory will wait a bit, now switch work with last config but I cant make and changes.
When need some changes will reset factory and reconfig again.
