admin password getting to default
CCR admin password is getting default. Is there any solution for this??
What version of ROS are you using?
I think that you’re having unoutorized access and someone is restarting your password for default.
Also you can try to change the username to see what happends.
Regards.
Thanks for the response. I have created multiple users, but all are getting removed and admin password is getting to default(blank). Present ROS is 6.44.3. I have faced the same issue earlier, i have reinstalled ROS with updated OS(6.44.3) its stable for few months. Again issue repeated.
For sure RouterOS does not remove users and does not change passwords by itself. Please properly Secure your device!
I have observed that whenever admin password is getting blank, i am unable to upload or download any file in the file list. unable to install latest ROS through package list. Even unable to make supout.rif file too
netinstall and password protect device.
Seems that your router goes into read-only mode. That can be caused by corrupted memory and/or HW issues. Netinstall your router to the latest RouterOS version, upgrade firmware and see if that helps. If not, then send supout file from your router to support@mikrotik.com.
