hi
i am going to start a big University hotspot based on mikrotik 2moro
i ma thinking of installing ROS on a PC with the config bellow
core i7 Processor
16Gb ram
1Tb hdd
i am expecting about 6000 concurrent users
and the max bandwidth would be about 50Mbps
is this sufficient??
cbrown
January 27, 2013, 9:42pm
2
How much queuing will you be doing?
Sounds like it should be fine.
for each user there will be simple queue with bandwidth limit of 512kbps
Kindis
January 28, 2013, 7:08am
4
16GB of RAM? To my knowledge x86 version is 32 bit and you can’t use more than 4 (32bit limit).
Sent from my Galaxy Nexus using Tapatalk 2
normis
January 28, 2013, 7:09am
5
RouterOS RAM limit is 2GB on all systems, except Tilera.
Kindis
January 28, 2013, 7:12am
6
One minute reply. Must be a record of some sort
And to hardware advice should cloud core router not be a good choice. My guess is that it won’t be much more expensive than a pc (unless you already have bought the pc)
