Somebody added game server’s to dude?
At me it is impossible to add Counter-Strike 1.6 server… How i can do it?
PS: Sorry for my English ![]()
Counter Strike uses range of ports (at least what I find in google),
For CS 1.6, the ports you need:
Start:End:Protocol
1200-1200 UDP
27000-27015 UDP
27030-27039 TCP
http://www.google.lv/search?hl=lv&source=hp&q=counter+strike+1.6+used+ports&btnG=Google+meklēšana&meta=&aq=0&oq=
You may try to establish communication with the ports on specific protocol.
I do this… But it always shows red… Like it off…
though Source server shows normal… (((
Then server is using another port. You can look in the Internet for the used ports.
