ADSL Connection Down Every 20 Minutes
Hi all…
I have a problems with my mikrotik. I used ADSL as my internet connection. Well…the problems is the connection down every 20 minutes. But when i disable-enable the interfaces that connect to ADSL modem the connection was UP again… :confused:
I have change the modem from SMC to other modem but it doesn’t solve the problem. I also lowering the interface speed to 10mbps, disabling auto negotiation and other option…i’ve tried all but it didn’t work… :open_mouth:
Anyone can help me???
I’ve used mikrotik v2.9.10 and 3 interfaces (One for ADSL, Wireless LAN, and for servers).
1st.. update your RouterOS you are back a ways…
2nd if it still happens, you may want to look at the NIC..
I use Intel NICs only… Pro100 PCI / HP / Compaq cards are VERY stable.
Craig
