Guys as the subject say.. I have adsl line with mtu=1442 (windows → command prompt → ping 8.8.8.8 -f -l 1414 with no fragmentation) + 28 = 1442
setting adsl modem in bridge mode and creating pppoe client to connect directly to isp through mikrotik
what value should i set with mtu i read on other posts the value should be (adsl mtu) - 20 (8 for pppoe header and 12 for tcp header)
so is that correct with such a low mtu value i get from my ISP → 1442 - 20 = 1422
and what mss value should i set in mangle rule
i put ppp profile change-tcp-mss to no in order to create the value manually at mangle section
Please the answer is so urgent to improve line speed .. Thanks
