Hi all,
I am using rb433 with ros 3.27. The hotspot working great as expected.
But when I try to use advertise, it’s not work at all.
Advertise URL : http://www.google.com
Advertise Interval : 00:01:00
Advertise Timeout : never
the google page never come out even if 1 minutes is over.
The pop up blocker is disable and already tried with opera, mozilla and IE.
Paul
The same here… Do you receive any help about this question?
I got ads to work in my hotspot, version 3.23.
But I only used local URL, like “advertise-url=advert.html”, to be put into hotspot-directory.
Does that work for you, at least ?
For me it doesnt work at all. Using incoming CoA Radius request, no effect. Radius reply has CoA-ACK status, so it has to be successful. Log file confirms that (see attachment image). test.html is at the root folder of this hotspot, checked with browser - manually typed address with /test.html at the end: seeing my test page. But no any pop-ups, redirects or something on client side. Where i should look for additional debugging?
