How do i advertise my network name in hotspot login window
You can modify your login page in any Web Page Editor like Front Page or Dremweaver. Just access your server through FTP e.g ftp://192.168.88.254:21 (In case of default port 21 you dont need to mention the port if you set any other port manually then type that port number after the IP and access your hotspot folder) Download the LOGIN.HTM page open it in any editor and make changes as you wish. But remember not to delete anything that is already on the page, because they might create problem for clients to login. Make necessary changes in it and then upload it again back to the same folder same place.
You can also use your domain, phone number, or advertising message as the SSID.
Tom
