How can I implement ads for mac authenticated users.
Moses
Moses
You can use that feature only with hostpot
Regards
Using the 2.9 hotspot you can use the advertising feature.
That should work regardless of the used authentication method in hotspot (i.e. mac login, for example)…
Best regards,
Christian Meis
It seems I can not for ip binding. Any suggestions?
There’s a difference between mac login (which i mentioned) and ip-binding.
MAC login uses the MAC address as username to login to the hotspot. There advertising WILL work.
IP-binding can be used to bypass the hotspot, so you won’t be logged into hotspot, and advertising won’t work, of course.
I don’t think there’s a way to make advertisment happen when NOT logged into the hotspot. You would have to use an external proxy with an appropriate solution there…
Best regards,
Christian Meis
