Advice for Configuration
Hi, All the valuable members and experts of the forum,
I need your kind help and advice for configuration of the scenario.
I’ve 4X Basebox5(5GHz) AP with 18dBi, 90 Degree RFelements Mimo Sector Antenna Mount on a 80Feet high tower to cover 360 degree, 1X Mikrotik RB450G ( As Principal Router to manage client’s IP addresses, Bandwidth, Traffic Prioritization etc.), 10X SXT Lite5 (5GHz) and 10X SEXTANT G 5HPnD CPEs, for my clients. Now my question is that,
  1. Can SXT Lite5 establish the connection from about 1-3km away from my base station? and Can SEXTANT G 5HPnD establish connection from about 5-7km away from my base station? (if there is clear LOS)
Can I control all the management process from Mikrotik RB450G, the Principal Router of my Base Station?
Is it possible which I’ve mentioned on my Scenario? If possible, please advice me for the best configuration step by step guide link.
Please help me.
A lot of Thanks for reading.
    Really MY client, on free of noise environment:
    SXT ~4Km
    Sextant ~10 Km
  2. Can I control all the management process from Mikrotik RB450G, the Principal Router of my Base Station?
    Yes, is possible, are not soo much users for now.
  3. Is it possible which I’ve mentioned on my Scenario? If possible, please advice me for the best configuration step by step guide link.
    I can not provide step-by-step guide, but your hardware, and your intentions are goods.
Thanks a lot Rextended,
Can you please advice me some general idea for for the configuration of RB450G and Basebox5?
Thanks once again.
I suggest you to contact one specialist for startup, is easy to start with the wrong direction…
