Advice for connect more access point from main router
Hello, has Cloud Core Router Board is a main, required to be a key link 4 Router Board so that all router change to 4 ACCESS Point to the original , if it has the main ip 192.168.1.0/24 so that each ACCESS dhcp take their point of main to any user “client” take ip from dhcp server “main router” to any one join in any 4 access point , What is the correct way to do
Make bridges on the APs between ethernets and wlan or use capsman.
Can you help me with example for how can i use
capsman
You can take ip in your method
Oh. Have you read manual already and tried at least something? Bridges are easier. Just create a bridge in the Ap, join the interfaces in it and it will work. You should move ip settings from individual interfaces to the bridge. Maybe the easier is to fully remove the configuration and set up the bridge and bridge members and wifi parameters as necessary (just in Ap bridge mode). That’s all necessary. Everything above that may be useful but is not so much essential.
