Advice on backing a 60GHz link with a private DSL line
I’m designing a setup for which a 60GHz radio link will be installed between two buildings.
One building host ISP lines while the “remote” has no ISP line at all.
Building are 60m from each other and I expect a 300Mb/s throughput through this 60GHz radio (Wireless Wire Dish).
There is a private telephony line between these buildings.
With a pair of CO/CPE VDSL devices, I can hope for a 80Mb/s throughput.
What do you recommend for this ?
  1. Using DSL line as a backup with automatic fail over
  2. Using DSL line as a backup with manual fail over
  3. Grouping both lines together ? How exactly
  4. Not using DSL line at all as 60GHz radio outperforms DSL
Best regards
With 60m clear LOS you van espect 1GBit with Wireless Wire you don’t need the dish
What are the technical downsides of using a Dish instead of a Wire ?
