Advice on CRS125-24G-1S-RM.
Hi all!
Can I take advantage of your knowledge to seek advice? :slight_smile:
I’m planning to restructure a small network which has:
  • about 15 among server, PCs and internet POS;
  • two ADSL connections (PPPoE modems);
  • a Ubiquiti UniFi with two SSID attested on different VLAN;
  • not more than 6 VPN remote access (PPTP / L2TP);
  • firewall for both ADSL routers.
The internal traffic is moderate, sometime there is a big upload, from outside to some internal servers, and one of the two ADSL is used for public WiFi connectivity (user band limited by UniFi).
I was wondering if this system is performing enough to do everything (switch, VLAN, VPN, ADSL, firewall):
http://routerboard.com/CRS125-24G-1S-RM
or if it is better to plan a separate managed switch with a router like this:
http://routerboard.com/RB2011iL-RM
Thanks for any hint. :slight_smile:
progettatamente,
Francesco P.
