I’m a first-time MikroTik user and has just bought a hap ac3 to replace an old wifi router. The router is connected to an ONT provided by my ISP. However, I wasn’t able to successfully configure the router from my laptop (running Ubuntu 20.04.2) following the instructions in https://wiki.mikrotik.com/wiki/Manual:Initial_Configuration and https://help.mikrotik.com/docs/display/ROS/First+Time+Configuration. The following setting is mostly the default configuration (with password set up for account and wifi access).
Any advice on the setting is very much appreciated!
Edward
# jan/02/1970 00:02:32 by RouterOS 6.47.10
# software id = ZZ0K-JU6F
# model = RBD53iG-5HacD2HnD
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=MikroTik wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=MikroTik \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=foo123 \
wpa2-pre-shared-key=foo123
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/tool mac-server
/tool mac-server mac-winbox
Thanks anav and rextended for your advice. I tried both suggestions but still not successful. The following is my revised configuration based on rextended’s advice.
Edward
# jan/02/1970 00:26:36 by RouterOS 6.47.10
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge \
protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n channel-width=20/40mhz-XX \
ap-bridge ssid=MikroTik-2 wireless-protocol=802.11
installation=indoor mode=ap-bridge ssid=MikroTik-5 \
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa2-pre-shared-key=foo123
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
192.168.88.0
/ip dhcp-client
/ip dns static
invalid
/tool mac-server
All suppose the ont is connected to ether1,
right?
Print the result of this command o the forum:
:ping 1.1.1.1
/ip dhcp-client print
if is missing DNS
paste this on terminal:
set servers=1.1.1.1,8.8.8.8
Another thing:
if the hAP must be a simpler Access Point without any routing function because the ONT already assign IP,
write this here and I make a script to convert the unnecessary routing functions with simple AP
It turns out that my ISP uses vlan tagging which I wasn’t intially aware as I’ve been using the ISP-supplied router so far After adding the vlan tagging, my router is finaly working
Here’s my working configuration. Appreciate all the helpful comments received!
Edward
add admin-mac=MM:MM:MM:MM:MM:MM auto-mac=no comment=defconf name=bridge
/interface wireless
ap-bridge ssid=Merlin2 wireless-protocol=802.11
installation=indoor mode=ap-bridge ssid=Merlin5 wireless-protocol=802.11
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
192.168.88.0
/ip dhcp-client
add disabled=no interface=vlan10
/ip dns static
invalid
add action=masquerade chain=srcnat out-interface=vlan10 ipsec-policy=out,none
/tool mac-server
