Advice on upgrading router
Hello all,
my current Mikrotik device is RB4011iGS+5HacQ2HnD and it servers me quite well. I use it as my main router and also as a home lab router for learning and playing with various network stuff.
However … I’m thinking of replacing it with this new hAP ax3 Mikrotik device.
The reason for this is mostly because it has WiFi gen 6 and WPA3.
Currently in my setup I have IPsec, Wireguard, bunch of firewall rules, hotspot …
I’m posting this to ask you for your advice and opinion, do you think this would be a good upgrade?
Get a hAP AX2 and play with it as a WAP. Don’t risk breaking what works for the first gen of their new wireless.
Thats nuts…
The RB4011 is a better router and if you want wifi6 there are plenty of decent APs already available.
If you want MT wifi, wait for the capaX to come out.
