we recvd a request to provide complete wireless connectivity solution for a Compound.. .. we are planing to setup mikrotik hot spot solution..we need ur advice on few things..
The Compound Area is 280 * 220 Meters.
it has 72 bungalows..each bungalow is G + 1 . all are individual ones..we need to setup wireless connection to cover all bungalows..am attaching blue print of compound..if any one can suggest us.
how many wirelss accesspoints can cover ths whole area.? which power of card shud we use.? how many db will work ? what directions antenna we might need. ?
do we need repeaters ?? what is best and reasonable equipment for us ? how can we setup wireless points??
thansks for your ideas or answers…
Edit:: removed my comment abt consultant… coz guys here concentrating more on the consulatnt part than my real question… i know u have right to express ur views. but still it wud be gr8 if anyone can answer my real question… …(removed blue print too)…
You’re the wireless consultant, so you should know how many devices you’ll need.
As far as what devices…depends upon what kind of service you’re offering. Once again, you’re the consultant.
Mikrotik devices available…pick from the list. http://www.routerboard.com/comparison.html
Consultants should have a basic knowledge of this.
