We have a situation,
as on the drawing we have a wireless bridge between 2 locations and a routed (Ospf) network on both ethernet ports.
for management and clients we have a bridges ( rstp ) with Mpls/Vpls tunnels on all the Mikrotik devices from all over the network to the Core router “Customer” bridge.
now i enabled Vlan on the Ubnt AirFiber with lets say Id 2010. ( in-band management enabled )
on the Mikrotik i create Vlan with Id 2010 and add that vlan to the (customer)bridge.
cool, now i can get in the Airfiber to do some management.
this will hold for some minutes, then the in between ethernet connections airfiber and mikrotik start randomly disconnects/connects on the Ethernet ports ( to be seen in the mikrotik log )
am I doing something stupid in configuration setup ?
If I disable Ospf on both sides I have no problem , I can bandwidth test an ping over the airfiber link between both mikrotiks for long time without problem.
did post this to Ubnt too.
ROS6.19 / AF24 on V2.0 firmware.
airfissue.pdf (230 KB)
